No signal from ECM
Old Oct 25, 2000 | 07:04 AM
EvilCartman's Avatar
Car: '82 Z28
No signal from ECM
Yesterday I took my 82 Z28 with the LG4 engine in to see what's causing the check engine light to be on. I had checked a couple days earlier and got a code 51. The mechanic plugged in his scanner and got nothing. The check engine light in the mean time was at half brightness which I've never seen it do that before. Any ideas on what the problem may be? A new ECM would cost about 100 bucks and I'm out of luck on getting a stock prom unless it's from a junker.
Old Oct 25, 2000 | 07:51 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
not much better, but if you need to get another ECM, check NAPA for remans...could be about 60-70
Old Oct 29, 2000 | 04:14 AM
Car: '82 Z28
Picking up a new computer Monday morning only 86 bucks, not bad at all. Hopefully it solves some other problems I've been having :/
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
