How do I tell if the computer is bad?
Old Oct 29, 2000 | 07:42 PM
BK's Avatar
BK
I've got a 92 305tbi with a 700r4 transmission. The torquer converter is not engaging so I have no fourth gear. My mechanic checked the transmission and its good since the rebuild about 10 mos. He's leaning toward it having a bad computer or a bad ground. How do you test for these conditions? Thanks for your response
Old Oct 29, 2000 | 11:27 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is a connector that plugs into the transmission for 4th geat detect & TCC control. The purple wire should have 12 volts to it when the ignition is on & the brake is not depressed. The tan / black wire goes to the ECM. It grounds this wire to engage the TCC. This wire also goes to the ALDL connector, so you can manually ground it there & see if the TCC locks up. The light blue wire is grounded by the transmission when it is in 4th gear - it goes to the ECM, as an indicator.
Tim
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
