speedo/tach
Old Oct 30, 2000 | 08:40 AM
tesla042's Avatar
speedo/tach
Hey.....I'm thinking about doing this crazy conversion car, and I'm not sure how the speedo/tach really works..
It's my impression that the ECM has a vehicle speed sensor thingy..or something.. Well, this project will be carbed, so there will be no ecm..
I'm thinking about probably a 2004r or turbo-350 transmission in it.. Is there an electrical signal off of that that reports driveshaft rotational speed? Where would I get the RPM signal from?
What I really want is some sort of varying signal........like 0v = 0mph, 5v=100mph, or something like that... I can scale it to whatever I need..
Any ideas, anyone?
Thanks,
-Tesla
91 T/A 305 tpi SD
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
The Wankel Rotary Engine - The replacement for displacement.
Old Oct 31, 2000 | 07:29 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Up to '89 the speedos are cable driven - except for some T/As & Berlinettas, in which case there is a VSS and VSS buffer (yellow box). In '90 - '92 the speedos are all electric & the VSS buffer is built into the ECM. If you don't want an ECM, you could get an external VSS buffer box & hook it to a VSS - if a 700R4 VSS will fit in a TH350. The output of the VSS buffer is 4000 pulses per mile with the correct tailshaft & VSS gears installed.
Tim
customblackbird
Apr 2, 2016 08:15 AM
jjcuff1
Feb 20, 2014 12:40 PM
fireturd350
Nov 8, 2012 05:17 AM
puffcat
Apr 1, 2006 09:46 AM
