need help with factory fog lights!!
Old Nov 2, 2000 | 04:11 PM
ScreaminDeamin85Z's Avatar
ok i bought new bulbs and it still doesnt work. tested new bulbs on battery and they work. is there a relay or a fuse? i have been jacking with this for a day and a half now and dont know where to turn next.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
Old Nov 2, 2000 | 04:34 PM
KS91Z28's Avatar
There is a fuse in the fuse panel under the dash. I think it says "Fog Lamps" or something like that.
Old Nov 2, 2000 | 04:48 PM
i dont see one that is labled fog lights. and none of my fuses are broken. the light that turns on when you turn on the head light works so that makes me think that the switch is good. please help someone.
Brandon
Old Nov 2, 2000 | 09:21 PM
Craig-'84-Z28's Avatar
Take your multi-meter or a test light and check for power at the back of the switch to be sure it's working properly. If all is fine there, then you'll need to trace the wires from the switch to the lamps looking for obviously bad sections (chafing). If your can pierce the insulation with your test tool, check several places along the wire to determine if it's broken somewhere. If all else fails, you may find it easier to just run new wires. I had similar problems with another '84 that I had before a drunk driver t-boned me. Hope this helps.
Old Nov 3, 2000 | 10:38 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your fog light switch has a green "fog light on indicator" light in it & it lights when the light switch & fog light switch are on, then the problem is in the wire between the fog light switch & the fog lights, or the fog light ground connection to the chassis. If the green light does not come on with the light switch & fog light switches on, then the problem may be the fog light relay, or the 20 ampere FOG LPS fuse, in the fuse panel (if you have that fuse). If you don't have the FOG LPS fuse in the fuse panel, one of the fusible links at the starter (the one that also powers the head / tail lights & the ACCY fuse) or the fusible link at the fog light relay may be open. The fog light relay may be under the hood, on the driver side fender, or under the dash, on the driver's side. You should be able to hear it click on & off when you turn the head lights on & off - the high beams must be turned off, and the high beam bulbs must be good for the fog light relay to energize, as well.
Tim
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
