HAVING ALL KINDS OFF PROBLEMS HELP PLEASE!!!!
Old Oct 26, 2000 | 10:30 AM
hookin88formula's Avatar
ok i just put all my gauges in my car. 4 of them to be exact. two mechanical and two electric. i decided to also put a manuel switch in for my fans. everything worked great till i put the switch in for my fans. i cant figure it out. i have no blown fuses but my power locks and my dome lights, plus my radio are not working. WHY???? i cant stand this. i do have all the power wires hooked into the fuse box. there is only one fuse box right and one spot for fuses? i need to know quickly what is wrong i cant stand not having interior lights at night..
thanks
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Oct 26, 2000 | 11:37 AM
Kevin S's Avatar
On the right side of your steering column,under the dash beside where the stereo/heater console is.There is a panel that pulls down.It holds your horn relay and stuff like that.
It holds a few fuse's.You may find your problem there.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited October 26, 2000).]
Old Oct 27, 2000 | 01:38 AM
ok i will take a look at that do i have to tear my dash apart ot find this? anyone else with ideas?
Old Oct 27, 2000 | 04:14 AM
Kevin S's Avatar
The panel is right behind the ALDL connector.
http://v6fbody.com/
[This message has been edited by Kevin S (edited October 27, 2000).]
Old Oct 27, 2000 | 08:37 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The panel behind the ALDL connector is called the "convenience center". It does not have any fuses mounted on it - only relay(s), the hazzard flasher, & the audio indicator. The devices you mentined that are not being powered all run off of the 20 ampere accy fuse, located on the fuse panel. Are you sure it is not blown?
Tim
Old Oct 29, 2000 | 09:28 PM
yes i am sure but this is the situation. i have 4 autometer gauges running into the fuse panel would that be to much? they ar run into blank spots. but they have power when the key is turned. i had no problems till i hooked the switch up into the car. but i still cant find any fuses blown. i have to check the back of my clarion cd player to see if there are any there. but that dont explain why the interior lights arent working. any help anyone.??
Old Oct 29, 2000 | 11:34 PM
ok could this have anything to do with a relay? or a sensor somewheres? some one has had to have this problem. please help this is driving me crazy!!! and is there a better way to wire the power to the gauges then putting the the wires into the fuse block? how about eh fan switch? the way i wired that is grounded the fans then jumped both fans together and ran the power wire to teh switch and since the switch has a light to tell me that its on i also ran that into the fuses block. the wire that turns the led on for the switch is what i think is the culprut but now that the damage is done i cant fix what i have done!! help..
Old Oct 30, 2000 | 03:09 PM
Kevin S's Avatar
I have a fuse in mine
Without it my stereo won't come on.
http://v6fbody.com/
[This message has been edited by Kevin S (edited October 30, 2000).]
Old Oct 31, 2000 | 07:33 PM
Wierd! What year is it & what is it? How many amps is the fuse? Is it a blade type, like the ones used in the fuse panel?
Tim
Old Nov 1, 2000 | 01:19 AM
it is a blade type in the fuse panel.. i found the fuse that is blown and the dome lights and the radio are now working.. i dont dare turn the fans on now though due to the fact taht i might blow a fuse any sugg..??
Old Nov 1, 2000 | 07:38 AM
If you are powering the fan motor directly from the fuse panel, a fuse will probably blow. Connect the fan switch to the coil of the fan relay & ground the other side of the switch, or, if you want the fans to be able to run with the ign off, add another fan relay & have the switch control the coil of the new relay.
Tim
Old Nov 1, 2000 | 12:33 PM
that sounds like a good plan but since i am not that good at this stuff can u explain it a little eaiser for me? whre are all these relays and stuff?
Old Nov 3, 2000 | 01:39 AM
Live305's Avatar
how exactly did you wire up your fan switch?
knowing this would help me make a better suggestion for you.
Old Nov 3, 2000 | 10:57 AM
There should be 2 fan relays under the hood - one for each of the two cooling fans. If you ground the green / white wire from a fan relay, the fan it controlls will run if the ignition is on.
Tim
jhawkeye
May 25, 2022 06:33 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
db057
Aug 22, 2015 08:17 PM
novaderrik
Aug 10, 2015 12:44 PM
Newguy91rs
Aug 7, 2015 09:51 PM
