hooking up rear defrost, relays?
Old Nov 7, 2000 | 08:47 PM
mike88RS's Avatar
bought a car with a rear defrost hatch, but no rear defrost. my question is: is the defrost on a relay, or is it just 12 volts 30amp out ofa switch
the ground on passenger side is already hooked up
thanks
mike
Old Nov 9, 2000 | 06:59 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The factory defogger switch is electronic & incorporates a delay circuit to limit the on time of the defroster grid. If you wanted to hook it up to a switch, I'd use the switch to control a 30 ampere relay. Get the relay contact power from the 30 ampere PWR ACC circuit breaker & get the relay coil power from the 10 ampere gauges fuse.
Tim
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
IroczFan
Oct 6, 2015 10:13 AM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
