Gauges
Old Nov 8, 2000 | 12:53 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Gauges
What is all involved with putting newer gauges in a 1984 ta. What year did the electiric speedo appear. I want ot get a set with the 140 speedo but what year will work? What else needs to be achanged. I know the gas and oil presure gauges are swapped. What will fix this problem? Thanks for any help. Kevin
Old Nov 12, 2000 | 12:44 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
hey, im trying to find the same thing out. E-mail me if you get a reply. Thanks
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
Eldebrock Headers, 3" Hooker Cat-Back, 2 nice tips with duel outlet on each side.
Mods: 1.6 Proform Roller Rockers, electric fan.
Future mods: X-Ram( Aftermarket Cross-Fire Injection Manifold that proves to have as much power as TPI www.x-ram.com )
Cross-Fire Injection after market chip that says that it will proform like 90's injections.. http://www.turbocity.com/CorvetteCro...ECMUpgrade.htm
Old Nov 12, 2000 | 03:17 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It will involve a major rewire job. Your best bet is to get a cluster from the junkyard WITH both connectors, and get a wiring diagram so you can see the pinouts. Any gauge that was an "idiot" light that you would now have an actual "gauge" for will require a new sending unit (idiot light senders are "on/off" switches, while gauge sending units are potentiometers (variable resistor)
As for the electric speedo, I think they were introduced in '86. You will need a speed sensor buffer w/ connector (I have one for sale) to hook up. Mine for sale is setup for cruise consrol, but you don't have to use it if you don't. You will also need to replace your mechanical gear in the transmission for a VSS. I will check back often to see if you have any more questions.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
