Turn signal flasher? Where is it?
Subscribe
Nov 13, 2000 | 08:36 AM
My turn signal flasher went out. It doesn't flash anymore, it just stays on. Where is it located? I do not want to scrounge around my car looking for something simple. Thanks! I am replacing it later on this afternoon along with those expensive brake lights.
1989 IROC-Z Convertible
305 TPI automatic
White with black top
Mods:
None to date... Working on it!!!
My webpage: http://mindspring.com/~humvee
[This message has been edited by Humvee (edited November 13, 2000).]
Reply 0
Nov 13, 2000 | 10:14 AM
Not really sure on an '89, but an '85 I had, it was attached to one of those retarded c-clip things that in turn was mounted to the steering column - way the hell up in there. In my '91, I think it's on the flip side of the fuse panel by the steering column that holds relays, buzzers, etc. I hope I was a little help - maybe someone can give you an exact location. Also it should be in your owners manual, if you have it.
KAM
Reply 0
Nov 13, 2000 | 12:24 PM
If your turn signals stay constantly on, it usually means you have a bad bulb someplace, so check that first.
Reply 0
Subscribe
