timing- - - HELP
Old Nov 22, 2000 | 01:59 PM
85berlinetta's Avatar
timing- - - HELP
I have a 1985 Berlinetta. It has the 305, and a carb. I think the problem i am having has to do with the timing. The car bogs BAD in between shifts (auto) and when i get on it. I attempted to adjust the timing, but the plate with the numbers is wnder the water pump! I can't run the car without the water pump. Please help! oh yah I am using a strobing timing light.
Old Nov 22, 2000 | 02:17 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You should be able to see the timing plate & mark on the balancer by peering straight down, between the water pump & the timing chain cover, if the timing degree plate is at 12:00 (viewing the balancer from the front of the engine). Other setups have the plate @ 2:00, which is a bit easier to see. Maybe your bog is being caused by a defective accelerator pump on the carb, or, if you have done mods, maybe it needs a bigger shot. Could be too big of a shot, too, if you have an aftermarket carb.
Tim
2firebirdpals
Oct 9, 2014 09:41 AM
ZZ42Fast
Apr 16, 2014 07:01 AM
RS-4-ReallySlow
May 20, 2004 06:25 PM
TRAXION
Sep 9, 2003 09:31 AM
