Those with LB9 and bigger cams
Old Apr 14, 2014 | 01:20 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I installed the Powermax 2032 cam- the largest the computer remains happy with or thereabouts.
The car is running a little lean now. I am going to fit the Holley AFPR and get the timing advanced.
Question is what should I bump the PSI up by?
Also what base timing- 8/10?
Anyone with real world results? Love to hear them
Old Apr 14, 2014 | 04:36 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Those with LB9 and bigger cams
Last year I installed a Comp 08-302-8 (similar to to the Crane 2032) in a 1988 LB9 with a 5 speed and 3.45 axle. Stock tune. Also put in a Holley adjustable regulator, and it runs pretty good at the stock spec but I plan on playing around with it some more because it's also running a little lean.
I've played around with the base timing, and it runs best at 6 degrees advanced and 91 octane. Plugs are R43TS.
Old Apr 14, 2014 | 05:20 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Use 93 oct if you have it available-
Old Apr 15, 2014 | 07:05 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
I think our fuel is around 95 octane. Anyone else?
Old Apr 15, 2014 | 07:10 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Send Tuned Performance a PM. He'll guide you in the right direction and could even give your ECM a tune if needed.
Old Apr 15, 2014 | 09:14 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I wouldn't mess with the fuel pressure first. I'd get the ecm tuned correctly.
Old Apr 15, 2014 | 10:55 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
That's good advice. I've already had many conversations with tuned performance. I was always going to do timing and fuel pressure and THEN do the ECM tune. Deffo the other way?
Cheers
Old Apr 16, 2014 | 07:01 AM
Jonesyfxr's Avatar
Tuned has helped me out greatly. I just have to do the ECM swap in my 85 Iroc now.
Jorlain
Oct 8, 2015 01:57 AM
Accerrito22
Sep 5, 2015 09:34 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
