ARGH!!!!
Old Nov 23, 2000 | 10:34 PM
B84305-Streetmachine's Avatar
ARGH!!!!
my temperature light comes on and stays on after the car is running..sometimes it cuts off and it says OK..but then it will come back on...it doesnt go off..even if the car is cold....im goin to put a new sensor in it......where is the sensor?.......and if this doesnt fix the light problem ......what else could keep the light on .... its an lg4 1984 ..305
Old Nov 24, 2000 | 09:13 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check my response to your previous post for the location of the sensor. The wire going from the cluster to the sensor may be shorting to ground, which would cause the light to come on intermittantly, as well.
Tim
Old Nov 24, 2000 | 10:09 AM
thanks......i checked your msg to the old post but i left another msg on it and u never replied. nm that.....thanks.....hopefully this wire is grounding under the hood....i bet its hard to take the dash off.....btw does the wire have a fuse or a fusable link anywhere?
Old Nov 25, 2000 | 09:13 AM
No fusible links in the temperature monitor circuit.
Tim
dans82bird
Carburetors
Sep 3, 2004 11:00 AM
D Stroy H8
May 6, 2004 01:50 AM
85_ZED28
Apr 26, 2004 05:09 PM
Hype
Oct 4, 2003 01:47 PM
CheezX
Jun 10, 2002 06:41 PM
