Car is completely dead...help!!!
Old Dec 1, 2000 | 12:30 PM
MelloYello's Avatar
okay...here are the symptoms...I turn the ignition key - no fire, no fuel pump whine, and no dummy lights. I have no horn, power windows, or headlights. Battery is good, but I suspect the propblem lie in the wiring between the battery, alternator and starter. This summer I put on headers, so perhaps they finally caused one of the smaller wires in the relay from the alt to the starter to short out.Any suggestions? please help!!! Thanks!
1990 Firebird Formula 350 speed density TPI; K&N, air foil, throttlebody coolant bypass, underdrive pullies, MSD 6AL, MSD HEI coil, 8.8mm wires, adjustable fuel pressure regulator, Hypertech Thermomaster chip, 160* thermostat, fan switch, B&M stage 2 shift kit, Edelbrock 1&5/8 headers, gutted dual cats, Flowmaster 80 series muffler, 3.73 posi rear end
Old Dec 1, 2000 | 06:13 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check the connections from both posts on the battery to where they terminate & use a voltmeter to find the open.
Tim
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
