fan switch w/ light..wiring
Old Dec 12, 2000 | 12:36 PM
UnderDogRS's Avatar
i'm installing a fan switch so i can turn my fan on at the track. im grounding the wire from the auto fan switch on the pass side of the block. when i wire the switch the ground wire goes the "power" on the switch. then another wire to a ground is connected to the
"ground" on the switch. and a 12v source is connected to the "acc" on the ****ch, right??
thanks,
RS
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
Old Dec 13, 2000 | 07:40 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you are referring to a lighted toggle or rocker switch, then the power, ground, and accessory terminals on the switch should be connected as follows:
Power terminal - connect to chassis ground.
Accessory terminal - connect to fan relay control wire that also goes to fan switch in cylinder head.
Ground terminal - connect to +12 volt ignition power.
With the connections above, the light in the switch & the fan will turn on when the switch is turned on, if the ignition switch is in the on position.
Tim
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
