Dash harness connector
Old Dec 11, 2000 | 08:44 AM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
I recently put my dash back together and drove my car for the first time in about 3 months (w/o a muffler, holy cr#p its loud ), but I couldn't remember where this one connector plug into. It is a small black square connector that branches off the harness right next to the cruise control "black box" on the passenger side. It is a female connector with several small pins protruding from it. Anyone know what this is for? Thanks.
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
Old Dec 16, 2000 | 12:26 PM
Im sure somebody knows! Please respond if you have a clue. Thanks.
Old Dec 16, 2000 | 10:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think I know which one you are talking about and I think mine is disconnected also. It may be for an option you don't have like rear defroster/defogger or Daytime running lamps (canadian).
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 17, 2000 | 11:12 AM
Thanks, GmTech. It's not for rear defroster, that connector is plugged into the switch further towards the middle of the dash. Maybe it is for daytime running lamps, which I dont have. I cant remember if it was hooked up to anything or not. It probably wasnt, because almost everything works fine when I drive the car. Thanks,
John
Old Dec 17, 2000 | 06:56 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sorry I didn't clarify. I know where the defroster "switch" is, I meant to say for the defroster relay, wich is in the general area you are talking about.
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Dec 17, 2000 | 07:19 PM
hmmmm.... my defroster doesnt work. Maybe this is why. What does the relay look like? There is metal box with a metal bracket that is further on the outside edge of the dash also hidden under that same trim piece and also connected to a small black connector....is this the relay you're talking about or is that for something else? If that is what your talking about, it is already hooked up. The connector im talking about is very small with a six pin lay out with two pins not filled:
1 2 0
0 3 4
there are several wires connected to it in the colors: 1)Red 2)Purple 3)Pink 4)White. I dont have a wiring diagram to look at, sorry. I hope this gives you a better idea of what Im talking about. Thanks a whole lot in advance. (sorry its long)
John
Old Dec 17, 2000 | 09:52 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Flip through here and see if you can't find it. http://www.geocities.com/vtcamaro/Wire-Diagrams.html
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
stalkier
Dec 6, 2015 11:25 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Slush92RS
Sep 2, 2015 08:56 PM
IBrockZ
Aug 20, 2015 12:20 PM
