JUMP START
Old Dec 20, 2000 | 10:26 PM
THE KID's Avatar
JUMP START
I HAVE A 91' Z28 w/350 THAT IS STARTING TO GIVE ME STARTING PROBLEMS. I'VE REPLACED THE STARTER, ALTENATER, BATTERY,AND BATTERY CABLES. WHAT HAPPENS IS WHEN ATTEMPTING TO START THE CAR THERE SOMETIMES IS NOTHING, LIKE THERE ISN'T EVEN A BATTERY CONNECTED, AND MOST OF THE TIME IT STARTS RIGHT UP. WHEN IT DOESN'T START RIGHT UP ALL YOU HAVE TO DO IS JUMP START IT NOTHING ELSE, AND THEN ITS FINE FOR SEVERAL STARTS OR DAYS THEN WITH NO WARNING IT WON'T START AGAIN.
1969 SS396/1971 307/1991 350 Z28
[This message has been edited by THE KID (edited December 20, 2000).]
Old Dec 21, 2000 | 12:15 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Maybe you have a short somewhere that is draining the battery. If this is the case, the longer you let the car sit, the less juice the battery will have. And by the way, THERE'S NO NEED TO YELL!!!
Old Dec 21, 2000 | 09:12 AM
812MANY's Avatar
It might be heat soak. You might want to try a "starter wrap".
Old Dec 21, 2000 | 07:34 PM
THE KID's Avatar
I HAD THE SYSTEM TESTED AND EVERYTHING CHECKED OUT,AND I'M NOT YELLING I JUST TYPE IN CAPS. I GUESS I'M NOT FAMILIAR WITH MESSAGE BOARD EDICATE!
Old Dec 21, 2000 | 08:46 PM
turbo497's Avatar
Hi kid, Typing in caps is like raising your your voice.. for instance "that car is REALLY UGLY!!!" the realy ugly would in a raised typing voice..
Anyway, I think you should check the positive wire that runs from your starter selinod to the ignition switch. I've had this go bad on two cars 84 pontiac fiero and a 1995 twin turbo stealth. the break in the wire was under the insulation and was a bear to find
3.8 turbo 20th anniversary transam #497 first owed by Clifford Williams, Bass player from rock band AC/DC
Old Dec 24, 2000 | 02:50 PM
82z's Avatar
82z
When does it happen? Is it first start in the morning or maybe after you shut it of and start it up a few minutes later? If it's the latter 812 may be right. When the starter solenoid gets hot it's internal resistance increases dramaticly. A jump would provide the extra amps it needs to start the car up.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Dec 25, 2000 | 06:28 PM
AustinT's Avatar
Hey I have the same problem with my 89 with a 305 TBI somtimes it starts no problem then sometimes I turn the key and nothing happens I mean Nothing no click or anything. When it happens I just have to push start it. I hope that when I swap in my engine Ill accidently fix the problem but who Knows.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
CORV3TT3
Aug 23, 2015 11:26 AM
cstrobel65
Aug 15, 2015 10:19 AM
