Blinker problem
Old Dec 31, 2000 | 03:06 AM
AmorgetRS's Avatar
Blinker problem
Here is what is happening, and thanks in advance for all who reply:
One blinker stays constantly on when I turn it on, no blinking action. This is the driver side/left turn blinker.
The right side works just fine....
Any ideas?
Thanks,
Douglas
Old Dec 31, 2000 | 03:15 AM
85F-body's Avatar
is it the blinking light that is by the steering wheel inside the car that is staying on or is the actual blinker
if its the light by the steering wheel then you have got a bulb out in that light you can get the bulb from the back of the light by reaching under the car
if it is the other possiblity then i would check and see if all my fuses are put all the way in and maybe even change it (if any other electrical problems accur)
Old Dec 31, 2000 | 03:21 AM
AmorgetRS's Avatar
Actually, forgot to mention, its a Firebird, I don't drive the RS anymore.
Anyway, it is both the inside blinker thingy and the outside ones, and all the lights work, they get brighter when I turn the signal on in the front and the back on turns on and just stays on....
Thanks,
Douglas
Old Dec 31, 2000 | 09:52 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Check your wires under the dash...does the blinker EVER blink? Try smacking the dash under your steering wheel and see if that causes a change. It's got to be either the wiring, fuse, bulb, or flasher but since the other one works it's probably not the flasher.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Dec 31, 2000 | 03:41 PM
CamaroEFI's Avatar
hey Amorget..just to let you know mine is doing the same exact thing. when i turn on the headlights the blinker light comes on and stays on and the outside left truning lights don't flash. if you find out whats up let me know.
Old Dec 31, 2000 | 04:58 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Well I hope I can help you guys out here cuz I've seen this before. I haven't dealt with it, but have seen it happen to others... It isn't the flasher - it's one of your bulbs on whatever side that's affected - either your front ones or back one. You just gotta find out which one, with either new bulbs or using a known good bulb to swap til you find it. Good luck, like I said, I hope this helps...
KAM
Old Jan 1, 2001 | 12:15 AM
AmorgetRS's Avatar
Okay, I guess I'll have that a shot... I'll try replacing the rear bulbs because I had just done some work w/ my new T/A tail lights.
Later,
RS
Old Jan 1, 2001 | 11:25 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You either have a bad bulb, a bulb in backwards (it DOES make a difference), a bulb wired wrong, or a bad socket. My wifes old car did this when we hit a deer and it broke the socket, and my friends corvette did this when the wire broke at the socket, and my car did this when the bulb.... It goes on and on. See if one of your bulbs isn't burnt out.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 1, 2001 | 11:25 PM
AmorgetRS's Avatar
I already checked the bulbs, the only thing that is wrong is that it isn't blinking. All bulbs work, only thing that doesn't work is the blinky part....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
