whats so good about 8mm wires
Old Dec 31, 2000 | 02:45 AM
85F-body's Avatar
what do 8mm wires do to help you in your car do they add hp or what ???
THANKS
Old Dec 31, 2000 | 03:27 AM
AmorgetRS's Avatar
I think the idea behind 8 mm wires is that they are thicker then normal plug wires. This means that there is more metal in there, which equals a lower resistance per foot then other wires. The lower resistance means more power makes it to each spark plug, in theory making more power. They help more the high the RPMs are, if I remember right.
I don't know how much they help stock, but they are a must with aftermarket ignition systems. I guess if you have the extra bucks to spare and need new wires anyway they won't hurt.
Later,
RS
Old Dec 31, 2000 | 04:51 PM
Yam's Avatar
Yam
The very first upgrade I did to my car when I got it was change the to Accel 8mm wires and Bosh +4 plugs. The car was totally stock and the difference was awesome. The throttle response increased and the smoothness accelerating was like I was driving a different car.
Old Dec 31, 2000 | 04:57 PM
85F-body's Avatar
is it hard to exchange the wires and how much does it cost to buy the wires???
Old Jan 1, 2001 | 01:36 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Accel has a universal set (unterminated, finish the ends yourself) for abut 25 bucks in most major parts stores.. I think the pre-finished sets were only 5-10 bucks more.. the swap should be a piece of cake if you do it right and *one* wire at a time as to not change your firing order.
'86 Camaro SC, black /w silver racing stripes
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
Old Jan 1, 2001 | 11:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The stock replacement wires for my car were 7mm, but I noticed the ones for 86 and older cars are 8mm. I went to Pep Boys and looked up Borg Warner wires, and bought the set for an 86 TPI F-body. They were $25, a year or so ago. All I needed was an extra 8mm coil wire because mine is a divorced coil. When I measured their resistance, the highest one was 2000 ohms. My dad has measured some of the "higher end" wires like Accel, MSD, Taylor, etc, and they come out to 15,000 ohms or more! For twice the price, even. Whats up with that?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 3, 2001 | 07:35 PM
need 4 speed's Avatar
Go with MSD super conductor wires.40-50 ohms
per foot.Put a set on my TA,love 'em.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
