Static Electricity
Old Jan 6, 2001 | 06:05 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
Static Electricity
Don't know if this is the right message board for this post, but since it deals with electricity here goes. I have an 85 IROC, no power anything. I do however, have an UNGO Box TL 4000 alarm installed under the drivers seat and an alpine amplifier under the passenger seat. Lately, when I get out of my car and shut the door I get a shock. I really don't know where to start as far as looking for a problem. Or is there a problem? I would appreciate any suggestions.
Thanks,
Clewis
Old Jan 7, 2001 | 04:23 PM
Biochem's Avatar
Car: 2002 SOM z28
Sounds like static electricity. I don't know of anything you can do except before you get out of the car, grap something metal and step out. That is what I have to do every time I get out. I also have a little keychain thing that looks like a hand with a wrist watch on it. Instead of a watch, it is a light and it will light up if you are going to get zapped. I got it from Japan for like $10 and I love it/ I absolutely HATE getting shocked. I'll even get juiced in the middle of summer for some reason. I'm quite paranoid about it too...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jan 8, 2001 | 01:58 AM
XxMoLexX's Avatar
I get the same thing. everyonce in a while ill get shocked. Sometimes its consistent and other times its not. Kinda funny actually. Specially when it happens to passengers and u see they do a lil jump when they get out and they try to act like nothing happened. But u know
But if anyone does find a reason lemme know! I wouldnt think its anything bad. Jus the carpet or something
Old Jan 8, 2001 | 02:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Static electricity build up is more of an issue in dry conditions, as the charge does not have a path (moisture) to bleed off through to ground. If the "static" charge builds up, it may bleed off in the form of a discharge through your body (a shock) to ground.
Tim
db057
Jan 10, 2020 08:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
