dnot know how to fix code 43
Old Dec 26, 2000 | 10:38 AM
weaselGTA's Avatar
i have tried every thing i need some out side help
WEASELGTA
Old Dec 27, 2000 | 10:11 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Code 43 is for the ESC (electronic spark control) circuit. What year & motor? In some systems the ESC is controlled by a module, external to the ECM (located under the hood, near the fire wall, on the driver's side), while in other systems, the ECM has the ESC control built into it. In any case, the knock sensor is the "microphone" for the system. The knock sensor is located on the passenger side, threaded into the block.
Tim
Old Dec 27, 2000 | 11:49 AM
weaselGTA's Avatar
91 gta tpi 350 i already changed the 1 in the dist still need more help put new ecm last night
WEASELGTA
Old Dec 28, 2000 | 11:44 AM
The module in the distrubutor would not be the problem with a code 43 - that module would only need to be changed if you had a code 42 (EST). Your code 43 points to the ESC circuit, which is the knock (detonation and preignition sensor). Disconnect the plug at the knock sensor, and verify that the dark blue wire that connects to the knock sensor has continuity back to the ECM - pin F9 (green connector), and that it is not shorted to ground. If there is continuity to the ECM, and no continuity to ground, then replace the knock sensor. If the problem persists, and the timing is set correctly (6 degrees BTDC), then replace the ECM.
Tim
Old Dec 28, 2000 | 11:56 AM
weaselGTA's Avatar
this all started by me putting new motor in big cam headers msd box coil afpr light porting but my headers hit the car so being semi smart i decided to move the knock sensor by making blue wire longer and put another knock sensor on the end of it but i h ad sa me problem did not fix **** dont know what to fix i already checked timing i just pulled the plug on the fender and set it at4
WEASELGTA
Old Jan 9, 2001 | 08:11 AM
weaselGTA's Avatar
i fixed it had to put a new mem-cal in it
WEASELGTA
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
