fog light voltage!? whats up with this!?
Old Jan 11, 2001 | 09:26 PM
leirch's Avatar
Guys, the factory fog light harnesses that are on my 87IROC are putting out about .05V?
Isn't it sposed to be 12V? What should i look for to be the problem? I haven't checked the fuse yet, is there any type of fusable link on them?
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Jan 12, 2001 | 12:40 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is a fusible link at either the fog light relay or the fog light switch. Check the fog light relay for operation - it will not turn on if the high beam bulbs are burned out or missing or turned on.
Tim
GTAman
Mar 15, 2019 11:40 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
