Car won't turn over
Old Jan 6, 2001 | 07:21 PM
Blue92's Avatar
Car won't turn over
Changed my heater core and put everything back together. Now the car will not crank up. Everything on the car runs(including a/c and headlights), but the motor and the hatch switch. I tried to see if jumping it would help but it didn't. I have no clue as where to begin my search. I hate electronics.
<A HREF="http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
" TARGET=_blank>http://albums.photopoint.com/j/View?u=1229597&a=9072781&p=29492901
</A> Harder"
Stock 305TBI,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft
Old Jan 6, 2001 | 08:36 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
Try turning on the headlights, and starting the car. obviously it wont start, but it will tell us if it is battery related.
1st car: 1979 corvette, power everything, leather, of course T-tops, KandyBrandyWine. &lt;-thats the color.
engine: Eagle Forged Pistions & rods, shaved heads, 10:1 compression, lifted cam (I think it was .274, nothing too extreme) small bore arround .020 open element air, dual freeflow exaust etc.
Tranny: sadly still a TH350, but plans for a T-56.
Other: L-88 hood, complete brake upgrade, plans for a 1"-2" drop a fiberglass rear spring, and 3:90 gears.
2nd car: 1985 WS6 Trans AM, power everything as well, glass T-tops which i love, chiped maroon.
Engine: bone stock sloth of an engine LG4, in need of valveguides.
Tranny: T-5. thank god, i couldnt stand an LG4 auto.
Other: in the works for a heavy hittin stereo system. Plans for an LT-1 or LT-4, but who know if its gonna happen. dual exaust, flowmaster mufflers, etc. some soft shocks and springs. i want to do the 4th gen style wing and RamAir hood, Paint the car Hugger Orange, and do the spoiler and ground effects black. Mail me if you have input on this.
i figgure, make the vette the fast one, and make the TA the one that rides nice. even though the vette is kickin the TA's AS$ in everything right now.
Old Jan 6, 2001 | 08:37 PM
85ws6TA's Avatar
Damn, guess i got carried away with my sig, dont worry, im fixin it now
Old Jan 6, 2001 | 08:44 PM
85ws6TA's Avatar
better?
1985 WS6 Trans AM
glass T-tops
T-5 tranny. thank god, i couldnt stand an LG4 auto.
also plans for dual flowmaster exaust,
Got the vette when i was 16, paid for it myself, screwd the engine up (idiot light didnt work, and i trusted the guy when he said he just changed the oil), and it turned into a project car.
Old Jan 6, 2001 | 11:50 PM
Omar's Avatar
The hatch switch is grounded through the gear selector switch. Your car will only start in Park/Neutral, as well as only opening the hatch in those gears. This is assuming that you have an automatic transmission. Do you?
1989 IROC-Z 5.7L
Old Jan 7, 2001 | 01:43 PM
Blue92's Avatar
Yes it is a auto. I just don't know where to look. Everything on the car works. I can even run my amp, a/c,headlights, etc.
The only thing that doesn't work is the hatch switch and the car not starting.
I changed the heater core and before I put everything back together, I started the car just fine, but once I got everything back together it would not start!
Thanks(Lost in GA)
Old Jan 7, 2001 | 02:21 PM
ArnoldBraker's Avatar
I am not an expert on cars but the first thing I would check is to make sure you didn't blow a fuse. Then i would like and see if there are wires around the heater core that you might have damaged. Just a thought.
Old Jan 7, 2001 | 02:46 PM
Blue92's Avatar
I checked every fuse already. Any other ideas.
Old Jan 7, 2001 | 02:58 PM
dude12387's Avatar
is it that your engine wont even crank at all, or that it will, but wont turn over?
If absolutly nothing happens when you turn the key, it may be your ignition switch, if you hear a click, or it wont turn, it could be your starter. I have no clue as to why your heater core would cause any of this.......
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
Old Jan 7, 2001 | 03:57 PM
Blue92's Avatar
It is probably just a coincidence that this happened at the same time. When I turn the key all the dash lights come on, but that is it. I also hear something in the back that sounds like the fuel pump I think but that only happens after I wait to try to crank it for awhile
Old Jan 10, 2001 | 12:06 AM
Omar's Avatar
Check your Park/Neutral Switch. Take off your shifter console. In front of your gear shifter, there are a bunch of wires going into it. There should be a green wire at the top. Connect this wire to ground and see if your motor starts up and if your hatch release works.
1989 IROC-Z 5.7L
Old Jan 15, 2001 | 02:22 AM
84blackbeast's Avatar
this is what is wrong with my car too. the key will not turn the car over, the hatch dosent work any more and the fuel cell or somthing makes a weird screaming noise.dang
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
