couple questions....
Old Jan 13, 2001 | 12:56 AM
edin's Avatar
ok, i have a few questions... how would i go about hooking up my brights, i pull back on the brights and they dont kick on, also, how would i go about hooking my stock horn up, the guy before me had an odd problem with unhooking everything.
i have a 1991 camaro rs.
Old Jan 16, 2001 | 06:51 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Chances are the previous owner just didn't align things correctly. The dimmer switch in the steering column probably needs adjusting, and if you pull the horn pad off there's a spring loaded assembly that might have been put back together wrong...thought it's pretty simple. As always, check fuses before you pull stuff apart, but those would be my guesses.
89 Iroc-Z LB9 TPI auto 2.73 posi:
3" Dynomax muffler, K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, accel 300+ wires, cap&rotor, synthetic oil, flexlite transmission cooler, afpr, !air pump&diverter valve, kicker sound system, soon to attempt engine swap...
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
