Is there a way to hook up the EGR solenoid when computer is gone?
Old Jan 17, 2001 | 09:27 AM
Biochem's Avatar
Car: 2002 SOM z28
I did the carb swap and now the carb and HEI are no longer run by the computer. The car runs great, but I have this fear come emissions time, they are going to say that my EGR solenoid is not hooked up right that I fail.
Is there a way to hook it up without the computer? Right now, the solenoid is not hooked up to anything (and the EGR valve remains closed). If I plug it into the harness, will it go mental and open the EGR valve, or is there a way to make it run correctly.
I hate the damn thing, but if I have to keep it on the car, I might as well try to make it work correctly...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jan 18, 2001 | 05:44 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If you must connect it for inspection, connect the EGR servo to a ported vacuum source - that does not have vacuum @ idle. You could also make the EGR solenoid valve wires disappear into the harness & not connect to anything if asthetics are all they would be concerned about.
Tim
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
pacoelrapido
Sep 11, 2015 02:41 PM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
