Where can I get a blinking light to mock a real security system???
Old Jan 16, 2001 | 12:03 PM
86IROCMIKE's Avatar
Like putting it near the transmission and can turn it on and off???
86 iroc,canary yellow,fully loaded
Old Jan 16, 2001 | 01:04 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Radio Shack sells flashing LEDs - if the LED is not a 12 volt LED (it has an internal resistor), you will need to put a 680 ohm resistor in series with the LED.
Tim
Old Jan 16, 2001 | 07:28 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you're handy with that kind of stuf, you could build your own, http://www.hioutput.com/tech/circuits/diagrams.html
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
Old Jan 18, 2001 | 08:13 PM
Chris Luongo's Avatar
Get a 12-volt flashing LED...hook the positive side (Is that the cathode or anode? I forget) to constant positive. Hook the other side to SWITCHED positive, like ignition or accessory. Then the LED will flash only when your key is off.
Old Jan 18, 2001 | 09:33 PM
Anode = positive
Cathode = negative
Don't forget a current limiting resistor, if it's not meant to run on 12 VDC.
Tim
pimp2303
Jul 27, 2017 02:03 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Tonyy_z
Aug 12, 2015 07:20 AM
Omega
Aug 10, 2015 12:46 PM
