interior lights sometimes flicker when car is stoped
Old Jan 19, 2001 | 08:41 AM
86blkIrocz's Avatar
when the car is at a stop and the head lights are on the interior and head lights flicker. It gets worse when I turn on the fog lights but as soon as I give it some gas or start moving the lights are fine. I was hopping someone could help me with this problem so I could fix it when I bring the car out of storage in the spring. I up a new battery in August of 99 it is a Sear's Die Hard. Thanks for any info you guys can give
David Higgins
1986 Black Iroc-Z
305 TPI
Edelbrock Cat-Back
K&N Air Filters
Old Jan 19, 2001 | 10:26 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like either the voltage regulator in the alternator, or the alternator is defective, or there's a poor connection in the ground strap between the block & the chassis, or the voltage sense line (small diameter red wire) to the alternator has a poor connection.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
