Hey Tim !! What is in the Headlight Solenoids?
Old Jan 20, 2001 | 08:35 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
What is the stuff that they put inside the Headlight Pop-up Solenoids? GM wants $250 apiece for new ones.
The only thing wrong is that the "friction material" inside them is ground up too finely and they slip when they try to pump up.
Does anyone know what this stuff is??
Old Jan 21, 2001 | 12:51 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
They are little plastic "*****". It is actually a saftey feature. Ford uses them in there window motors, that way if the window gets rolled up with your arm out the window, the ***** will crush before your arm. Unfortunatly, time and wear will also beat the ***** to a pulp. One fix for this, and this is not a reccomendation from me, but it works, is using I think 10mm nuts from the hardware store. Just hope nothing gets jammed in there.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 21, 2001 | 09:17 PM
Thanks GM Tech. Coincidentally, last night I figured this out and a friend who words at Auto Zone confirmed this...
Auto Zone sells a Siemen's Window Lift Gear Kit for Ford Power Windows with the three hard-plastic spacers. The spacers are the same plastic spacers that Pontiac uses. The kit is part #84634 and they are about $23 each. Both solenoids now work perfectly. Again Thanks!!!!!!
jtwoods4
Jan 22, 2018 01:13 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
z28guy134
Sep 1, 2015 11:50 PM
Fox118
Sep 1, 2015 04:07 PM
