CTS keeps failing, electrical problem????
Old Jan 23, 2001 | 06:28 PM
irocbsa's Avatar
I have replaced my coolant emp sensor 3 times in the past 12 months. About every 12 weeks I get a code 15. I don't know what is going on. I soldered the connections on the new harness and applied dielectric grease to the sensor plug. This is really starting to get on my nerves. Does the cts wire directly to the ECM harness. Should I replace the entire length of the wire? Could the failures be caused by old, dirty coolant? I was told that this could be an electrical problem such as a short somewhere. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
toones
Jan 6, 2016 06:00 PM
JHX
Aug 29, 2015 02:30 PM
Bryan F
Aug 27, 2015 07:28 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
