Need help on wiring a kill switch/
Old Jan 30, 2001 | 11:35 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
I am needing some help on wiring a kill switch in my 91 firebird. What would be an easy but effective way? Thanks
Randy Effler
Old Jan 30, 2001 | 01:49 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The fuel pump supply wire (tan / white stripe) runs through the plastic conduit on the driver's side, under the sill panel carpet (left hand side of the driver's seat) - opening that wire will make the motor unable to run.
Tim
Old Jan 31, 2001 | 09:26 PM
Stell1579's Avatar
i tappe dthe wire that controlls the starter i believe. its a thick (prolly 10guage) purple wire that runs along the floor in the drivers side when it is open, the starter willnot turn, but as a sideaffect, my hatch doesnot pup from the switch on th econsole eithere
but it works with no shorts or probs
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, 180 Thermostat+ Temp Switch, Relocated MAT, Cold Air. Soon to have Edelbrock TES Headers,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
Old Feb 1, 2001 | 12:44 PM
If you change the splice point from the purple wire after the PRNDL switch to the yellow wire before the PRNDL switch, your hatch release will work. Make sure that you make the splice up stream of where the hatch relay wire (yellow) connects to the PRNDL switch. The hatch relay gets its ground through the PRNDL switch and the starter solenoid coil when the PRNDL switch is in P or N. This prevents the hatch from being released while the PRNDL switch is in any other position than P or N.
Tim
Old Feb 1, 2001 | 12:57 PM
El Guapo's Avatar
just on a by the way note, if you pull the brake handle up enough to get the dummy light on, the hatch will work in any other gear position besides P or N
Old Feb 2, 2001 | 03:16 AM
Omar's Avatar
That is incorrect. The hatch switch is grounded through the parking brake only on manual transmission cars. On automatics, it is wired as Tim states, and only working in Park or Neutral.
As an additional by the way note, I recently purchased and installed a Painless Wiring Hot Shot Plus Relay with a bump button. Since this setup interrupts the ground to the hatch release button, my wiring job had to stray some from the directions. I also had to use a SPDT relay versus the SPST relay they provided. Just giving some heads up to anyone making this addition with an auto tranny.
1989 IROC-Z 5.7L
[This message has been edited by Omar (edited February 02, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
Bryan F
Aug 27, 2015 07:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
