Blinker help!!
Old Feb 1, 2001 | 10:37 PM
RenoLB8's Avatar
Blinker help!!
I put underdrive pulleys on my 'bird a while ago, and the blinkers have REALLY slowed down, like I mean almost not blinking. Any way that I can speed them up? I was thinking maybe the relay/capacitors out of something that blinks a lot faster, so it'll be at a medium rate? Any help or suggestions appreciated.
-Reno
Old Feb 2, 2001 | 07:37 PM
MrF-body's Avatar
the pulleys slowed down your alternator, witch then isn't putting out as much voltage, that's why your blinkers are slow
Old Feb 2, 2001 | 08:34 PM
RenoLB8's Avatar
That one I was aware of, I"m just looking for a way to speed them up again without taking off the pulleys.
-Reno
Old Feb 2, 2001 | 08:41 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Maybe an electronic flasher unit???
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
Old Feb 3, 2001 | 06:51 AM
MrF-body's Avatar
good idea pete.
Old Feb 3, 2001 | 01:04 PM
RenoLB8's Avatar
What is it, where can I get one, and how do
I rig it up? I'm not as clueless about electronics as I now sounds, but this is definately a new idea to me...
-Reno
Old Feb 3, 2001 | 06:15 PM
MrF-body's Avatar
i think our cars use a 555 flasher unit, go into your local parts store and tell them you want an ELECTRONIC 555 flasher. it will look like a relay instead of the little metal canister. it just plugs in where the old one did.
Old Feb 3, 2001 | 08:20 PM
RenoLB8's Avatar
And this will blink at a constant rate even with the lower voltage? If so, thanks!
-Reno
Old Feb 4, 2001 | 08:28 AM
MrF-body's Avatar
it should, it is timed electronicly, not by the voltage/load placed on it
have a beat to hell 87 GTA 305ci 700r4
t-tops,recaro,honeycomb wheels,digital dash
paid $600 at a junkyard for it (i had to save it)
Old Feb 4, 2001 | 01:12 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Replacing the thermal flasher with an electronic flasher will cure the problem. I used one in my Z for the same reason, after installing under drive pulleys. Pep Boys, AutoZone, Checker, etc. sell the electronic flashers - they run about $6 - $8.
Tim
Old Feb 4, 2001 | 01:38 PM
RenoLB8's Avatar
Thanks for the help. Now just cause I'm lazy, and as long as we're on the subject, where are the flashers located? =)
-Reno
Old Feb 4, 2001 | 04:17 PM
MrF-body's Avatar
i do believe the flashers are in the fuse box. one is for hazards and one is for turn signals
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
