Performance Plug Wires
Old Jan 26, 2001 | 10:25 PM
BlueIrocZ's Avatar
Who makes the best FITTED, not universal, spark plug wires for a 350 TPI camaro? Two of my universal Accel 8.8 boots ripped when taking them off to install headers and I don't want to go the PITA to custom fit them
again. Any help is appreciated. Also Who makes the best oversize gaskets for having a stock tpi manifold base being ported to?
89' 5.7L TPI Auto IROC American Racing Torque-thrust 2 rims ,Ported Plenum,Accel/Lingenfelter Runners,
Flowmaster, high-flow converter, SLP headers, B&M console megashifter, MSD 6aL, airfoil, K&N's,Gutted airbox, Bosch Platinum +4, 8.8 wires,Accel Coil
Old Jan 27, 2001 | 02:35 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Did you use silicone grease on the interior wall of the boots, before installing them on the plugs? If not, the boots will rip off fairly easily when removed from the plug. I have tried Taylor, Jacobs, and TPIS (MSD may also make a pre-cut version, but I've only tried their universal set) pre-cut wires - they were all well constructed.
Felpro 1204 intake gaskets are 1.23" x 1.99" & work well for a porting template on the heads & intake. They also include heat riser block off plates. Also, Felpro 1444 header gaskets are 1.38" x 1.38" & work well as a template for the exh side of the heads.
Tim
Old Jan 28, 2001 | 07:16 PM
BlueIrocZ's Avatar
Nope. I didn't use the silicone grease. Who sells the Felpro's and how much do they cost?
Old Jan 29, 2001 | 02:26 PM
Summit, Jegs, your local spped shop - approx $15 - $20 a set.
Tim
Old Feb 4, 2001 | 05:09 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
BEST = Packard Electronic GMPP Racing wires - over $200 a set unless you work for GM. You can get the red 8MM ones for about $75 from scoggin dickey, plus they are waranteed so they're the last you'll ever buy.
PN#: 12361051
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: Accel 300+ wires, cap&rotor
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, hopefully engine swap and 4th gen seats in the works...
[This message has been edited by I ROCK (edited February 04, 2001).]
Old Feb 5, 2001 | 12:59 AM
Z_Ghost's Avatar
I got the MSD wires on my 92 and they fit really good.
Old Feb 5, 2001 | 01:29 PM
BlueIrocZ's Avatar
***a local***!!! thanks everybody for your input and help.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
