Do I use a fuse?
Old Feb 12, 2001 | 11:14 PM
mcconahay37's Avatar
Do I use a fuse?
I've had my Crane Hi-6 ignition in my car since last June and have had no problems. When I installed it, I didn't put a fuse between the battery and Hi-6 because the instructions didn't say anything about whether or not to use one. Lately that's been bothering me. Should I go back and put a fuse in and if so, what size should it be?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
Old Feb 13, 2001 | 08:43 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Personally, i would NOT use a fuse because thats the main feed to power your ignition and a fuse would pose a restriction. If it really bothers you i'd recommend using a fusable link 2 gauges smaller (bigger #) than the power wire.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
