Installed trans temp gauge, won't work
Old Jun 24, 2002 | 09:21 AM
formul8!!'s Avatar
Car: 2004 GTO
I installed an Autometer trans temp gauge yesterday. The light bulb works, but the gauge does not.
Which terminal do I hook it up at. the "S" or the "I"? Also, do I have to ground the gauge too? I wonder if the sender welded into the trans pan is bad?
Any help would be appreciated.
Old Jun 24, 2002 | 10:28 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
The sending unit needs to be grounded.
Had the same problem before.
Ran mine near the raidator.
Old Jun 28, 2002 | 03:08 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Ditto. I assume you bought a "manifold" to splice into the hose for the sending unit. Solder a wire from the manifold and run it to any ground. It will work then. I beleive the sender wire rund to the "S" on the gauge.
1992rs/ss
Jan 31, 2025 05:10 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
fonzie85
Aug 13, 2015 11:50 AM
Irocohio
Aug 12, 2015 08:03 AM
