Help with radio please
Old Jun 28, 2002 | 07:30 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
the other day i hit the power button on the stock radio in my 84 t/a to turn it off and the antenna went down as it should, but now the radio doesnt come back on and the antenna never goes up. I checked my fuse box and nothings blown, what else could it be, any other fuses i need to check, i didnt see any behind the radio. Also it still is keeping time right though it did reset it after it was turned off and the car was turned off then back on.
If it matters the radio is the stock tape deck with 3 band eq and the amp driven 5" subs in the sail panels. Thanx.
Old Jun 28, 2002 | 09:27 PM
DigiTalZ28's Avatar
Just a guess, but it sounds like that 18 year old power switch finally wore out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
