Replacing headlight/turn signal/windshield wiper switch
Old Feb 23, 2001 | 10:03 AM
89RSProject's Avatar
I Need to replace my switch, because of the windshield wiper controls. My car is equiped with cruise control. Is this easily removed or does the steering column need to be torn apart. Currently my wipers is unattached under the hood because they will not turn off, and it is raing more and more here. Any help on this is greatly appreciated. Thanks in advance.
"Blaming murders on guns is like blaming spoons for fat people"
Old Feb 24, 2001 | 11:34 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The windshield wiper switch is controlled by the multifunction lever, but is not part of the multifunction lever - it is mounted to the column. To get to the switch , you will need to remove the multi function lever. To remove the multifunction lever, make sure it is in the "off" position & pull it out of the column.
Tim
Old Feb 25, 2001 | 10:00 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Do what Tim said. Then to replace the wiper switch, you have to pull the steering wheel, remove the lock plate, remove the turn signal switch, ignition cylinder, and the 3 torx bolts that hold the plastic shroud down. A metal pin holds the switch to the shroud. Its not too bad. I just did it when i installed my intermittant wipers. I had to unbolt the column too so i could pull out the wires for the switch.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Feb 26, 2001 | 03:26 PM
Thanks for the info. I'm pretty sure its just the multifunction lever that needs replacing. So I guess my question is how is this accomplished?? Thanks again.
Old Feb 27, 2001 | 08:44 AM
So the multi function lever, in the off position, will just pull right off??????
Old Feb 27, 2001 | 05:04 PM
So nothing is going to break if the switch is off, and I gently pull the multi function switch straight out. Well, I suppose there is always a possability of breakage with anything. Is there any way to test rather or not it is the multi-lever or the switch itself. The windshield wipers stay on at a "low" speed when I switch the lever to the "off" position. Thanks again and sorry for the persistence but its calling for rain here for the next week and its truley a huge PITA to pop the hood everytime it starts or stops raining.
Old Feb 27, 2001 | 08:24 PM
?-Do you have intermittant wipers?
Just pull straight out. Its scary the first time, but after that, its fun to do. I can almost 100% guarantee that its not the lever. The lever only turns the switch. The switch is what decides what signal to send to the wiper motor.
-Justin-
Old Feb 28, 2001 | 08:39 AM
Yes I do have the intermitent wipers. Is there any way to test or should I just replace the switch first??
Old Feb 28, 2001 | 02:36 PM
You should check the switch functionality at the connector under the column with a volt meter, to determine if the problem is the switch, or the control module in the motor assembly, first. If you don't have a shop manual, you should be able to find the wiring diagrams at:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
slade5612
Aug 11, 2015 07:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
