fans one works one doesn't???
Old Mar 1, 2001 | 05:04 PM
millertime's Avatar
Hey! I was under the hood the other day (been spending way to much time there the past few weeks) when I seen only one fan working. I went direct to the fan with a hot wire and it worked. checked the relay on the passenger side had juice comming in but not out. Jumped two wires there and the fan worked. replaced the relay and the fan still does not work. Is there any other relay or something else to check?? HELP!!!
Old Mar 1, 2001 | 06:02 PM
RC's Avatar
RC
if i'm not mistaken,
one fan is suppose to come on when the computer is suppose to sence over a certain temperature <from the coolant temperture sensor> to turn on the fan.
the other fan is only suppose to come on when the A/C switch is engaged.
anyone agree or disagree?
Old Mar 1, 2001 | 08:45 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yep - you got a primary that comes on at a pre-determined temp, and the other will kick in if you select A/C or defrost...
KAM
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
