How to hook up boost gauge?
Old Mar 9, 2001 | 03:47 PM
theformula's Avatar
How would I hook up an Autometer 1 5/8" sport comp boost gauge. WHere should the vacuum for boost reading be taken from in the car?
thanks
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 9, 2001 | 04:31 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Directly from the plenum. Make sure the gauge is spliced in line before (not after) the check valve that connects to one of the hose barb fittings on the RH rear of the plenum - it supplies vacuum to the interior accessories & cruise control.
Tim
69GTOby
Apr 18, 2016 02:34 PM
customblackbird
Oct 1, 2015 04:30 PM
gta892000
Sep 16, 2015 12:37 AM
Doobie52
Sep 11, 2015 06:19 PM
