cruise don't work
Old Mar 26, 2001 | 05:32 PM
Ragin'87's Avatar
cruise don't work
just bought a 92 RS yesterday.., it's my 2nd 3rd gen, both have had cruise, but neither worked. My center brake light doesn't work either(didn't work in the 87.) Do these two have anything to do w/ each other. The blub isn't busted(that I can see) on the brake light, and I haven't had a chance to check for voltage. Where should I look to try and find the source and fix these problems.
Anthony
Old Mar 26, 2001 | 05:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Both my 91 Z28 and 92 RS had loose bulbs in the third brake light. Try removing the bulb and carefully prying out the contacts a little bit. That will make it fit better in the socket. Make sure its a good bulb, of course.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 26, 2001 | 06:59 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Also look carefully at the bulb socket, these tend to crack after awhile and the contacts get loose. Corrosion is also a factor.
Not sure what to say on the cruise, i'm still trying to fix mine with no luck. Tim Burgess sent me a schematic, if you can read those then ask him for one, it should help some.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
Old Mar 26, 2001 | 08:24 PM
Ragin'87's Avatar
thanks guys, I didn't think to check the bulbs fit in the socket. It seemed to fit fine, so I'll check voltage and whatnot tomorrow, otherwise I don't know.
Anthony
midias
Aug 22, 2015 01:42 AM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
matthew911
Aug 12, 2015 09:38 AM
Bull86
Aug 10, 2015 05:43 PM
