plug lighter in, fuse blows...
Old Mar 31, 2001 | 01:29 AM
irocz_ca's Avatar
what could be wrong when you plug in your lighter thing and the fuse blows? anyone with the same problem on his/her irocz camaro?
Old Mar 31, 2001 | 07:40 AM
91RS_Sweden's Avatar
I have exactly the same problem with my lighter! have no idea of what to do.. hope someone knows.
Old Mar 31, 2001 | 09:15 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
sounds like your lighter's coil element is shorting out. Does it look corroded or distorted? Go get a new one and see if that fixes it. Otherwise the retention clip in the socket is bent up and shorting when the lighter gets pushed onto it.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old Mar 31, 2001 | 09:26 PM
Luke's Avatar
Car: '86 Camaro
Engine: 2.8 MPFI
Maybe the lighter its self is FUBAR'd causing the circut to close without the resistance of the heat coil. Try and use something else like a radar detector or phone charger with a good fuse in and see if it works. Worst you could do is pop an other fuse
Old Mar 31, 2001 | 10:18 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
From what I heard it's a GM problem.. mine has the same problem.. so I just leave it out.
Old Apr 1, 2001 | 08:15 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
I hade the same problem when i first got my car, look inside the part mounted to the dash and see if the prongs are pushed realy close to the edges. Of they are, your lighter is grounding out the terminal ment to go to the inside edge of the element. I tried to bend mine back and broke it. But the replacement piece that goes inside isn't very much at discount or autozone etc. Hope this helps. Laters
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
Old Apr 2, 2001 | 04:08 PM
jm91rs's Avatar
mine does the same thing too..It's annoying, but i just avoid using the lighter socket.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows
Old Apr 3, 2001 | 11:43 PM
Don Anderson's Avatar
I had the same problem with my 89 RS Convt
every time I put the phone charger in out went the fuse. For $10.00 I bought a replacement from a parts store. No problem anymore. Wish everything I have had to fix costs so little...
For instance, the alternater, the starter, the timing chain, exhaust system...still trying to find out what the timing should be set at. Hood says 0 degree the chilton 8 degree..
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
90formulaVortec
Sep 3, 2015 09:26 AM
