Making cruise work with no wiring harness or ecm
Old Mar 29, 2001 | 11:05 AM
87Z-ya's Avatar
I just switched to a speed pro ecm, and gutted the factory computer harness and ecm. I still have the vss and was wondering how I can make the cruise work???? Thanks...
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Apr 8, 2001 | 03:02 AM
87Z-ya's Avatar
ttt
Old Apr 8, 2001 | 11:52 PM
cfabe's Avatar
do a search on this board, there is a website out there with a very good description of the VSS system, which will be a good start for you. I've posted the adress a few times but I've lost it on my comptuer. As far as the cruise is concerned, get an electronic/vacuum setup. I found mine in my 86 parts car. You'll have to slit the covering on the dash harness to get the cruise wires out, but the only ones you'll have to cut are the system power, the ground, and the vss input wire. Then just put everything back togther and wire it up properly. It would probably help to have a wiring diagram of the car the stuff is coming from.
Old Apr 9, 2001 | 09:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your VSS is still located on the rear of the instrument cluster, then connect the VSS output (brown wire) to the cruise control module. The rest of the cruise control connections may be found at:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
matthew911
Aug 12, 2015 09:38 AM
marcusaw
Aug 10, 2015 08:13 AM
