DELETING THE ECM WIRING HARNESS
Old Apr 5, 2001 | 11:26 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Is it a big problem to isolate the ecm harness and get rid of it?My car has used a non-computer carb and distributer since i've had it,and the old harness lays in the engine bay like a bunch of snakes.I would really like to clean it up under the hood,but i don't want to mess everything else up.I'm sure some one out has done this,and any advise would be much appreciated.
Old Apr 6, 2001 | 03:17 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It is not much work to do, if you have the Helm shop manual wiring diagrams.
Tim
Old Apr 6, 2001 | 11:51 PM
burnoutrpm's Avatar
i did it good luck its a bitch!! i dont care what maual you have! ive dont it it sucks just leave the fuel injection harness alone!!.....trust me your biting off more than you can chew!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 9, 2001 | 04:12 PM
Let me restate that - it's not much work, if you know what you are doing, and you have the wiring diagrams. I've done a TPI to carb harness conversion, and a carb to TPI harness conversion. The TPI to carb conversion involved about a day's worth of work of harness modification, while the carb to TPI conversion involved a considerably larger amount of time and effort, as it required a completely new harness installation and additional power distribution.
Tim
Old Apr 9, 2001 | 06:58 PM
TopForm's Avatar
I've done this also, and there is alot of work involved but it is pretty much straight forward. Nothing too awfully hard, but time consuming.
Brian
1987 Firebird Formula
Currently undergoing full restoration
Old Apr 12, 2001 | 02:36 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
Been there...DID THAT! ! !
Make sure not to clip the wires for your windshield wipers or cruise control
<marquee type="slide"> </marquee>
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
djmarch
Aug 19, 2015 12:07 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
