Help, I think I fried my ECM
Old Apr 14, 2001 | 09:34 PM
Mike86SC's Avatar
I have an '86 Camaro with a 350 swapped in, & it had the original computer-controlled Q-Jet. It ran fine, I got a SES light fairly regularly, but it never affected the performance of the car. Today I swapped in a new computer-controlled Q-Jet to replace the old one. When I was done, I drove the car, & it drove beautifully for the first 2 minutes or so. Then the SES light came on & everything went to hell. I could tell I wasn't getting any timing advance, the car ran like total crap, barely even staying running. I limped it home, turned it off, then turned the key to ACC. The M/C solenoid didn't respond at all (no clicking sound). I started it again & I immediately got an SES light & it stayed on. Car would barely run & had no throttle response. So, does it sound like I fried the ECM? If so, if I simply replaced it, would it likely fry again? What could cause this? I really don't know what to do here, any advice is welcome, thanks!
Old Apr 15, 2001 | 10:40 AM
Mike86SC's Avatar
Oh yeah, I just remembered that my dumb *** neglected to diconnect the battery before I started the project, if that helps any.
Old Apr 15, 2001 | 09:56 PM
Vader's Avatar
Mike,
It sounds like it's a good time to clear and reinitialize the ECM. See the Tech Articles for details, or search the archives.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 16, 2001 | 03:01 PM
Mike86SC's Avatar
Vader, thanks for replying. I can't find anything in te tech articles or in the archives to help me, though. Is there an easy way you can explain it to me? Thanks for your help.
Old Apr 16, 2001 | 03:26 PM
Mike86SC's Avatar
Nevermind, I figured it out, I'll let you know what happens.
Old Apr 16, 2001 | 03:39 PM
Mike86SC's Avatar
Vader, there was no change. The M/C solenoid is still unresponsive & everything. I couldn't find any connections or wires that had been melted or cut. I'd appreciate any other suggestions. Either way, I appreciate your time & help.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
