Finally-An answer to the 'buzzing choke light' question
Old Apr 23, 2001 | 01:01 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I was able to get my hands on the shop manual for my '86 Z and while reading through the electronics section, I found the answer to one of my biggest headaches. The Idle Speed Control Relay will buzz for up to two minutes while the car recharges a discharged battery. If it buzzes any longer(like about six months in my case) it means that your battery isn't getting a charge. There are several problems that could cause that-bad diode trio, bad battery, etc, but there it is, in writing, finally. Hopefully this helps a few of you...
1985chevydude
Aug 20, 2015 12:29 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Omega
Aug 10, 2015 12:46 PM
