POWER DOOR LOCKS JUST QUIT!!!!!
Old Apr 23, 2001 | 12:56 PM
86IROCMIKE's Avatar
Now all I hear is a small click when I hit the button,is there a fuse somewhere??Any ideas????
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,3:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER 180 WATT CD RECIEVER AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!and my love for the IROCZ
Old Apr 23, 2001 | 09:08 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Is the fault intermittant or is it happening 100% of the time?
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old Apr 23, 2001 | 11:43 PM
86IROCMIKE's Avatar
It just died yesterday when I hit lockor unlock there is a small clicking noise coming from near the fuse box,how doI fix it?????
Old Apr 24, 2001 | 07:18 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Does it do the same thing from the other door as well, if you try the lock/unlock buttons on the pass door? May be that your switch has developed corrosion on the contacts. My '85 did that once...
KAM
Old Apr 24, 2001 | 03:33 PM
86IROCMIKE's Avatar
Yes both doolocks do not respond and all four buttons don't work,is a fuse,what do you guys think??
Old Apr 26, 2001 | 06:59 AM
Car: '91 Z28
Axle/Gears: 323's
Sorry I didn't get back to your post yesterday... I'd check the fuse, but I'm sure you've already done that by now. I'll look in my book tonight to see what else is in the wiring for you...
KAM
Old Apr 26, 2001 | 10:04 AM
gmanuel's Avatar
the clicking is a relay which is behind the kick panel on the drives side. If you are hearing the click then there is poer to the relay. Check to make sure you have a good ground at the relay.
Old Jul 28, 2002 | 11:02 PM
1991 RS 305's Avatar
Allright, I just began having the same problem, checked ground... it's good. I am also hearing the small click from a relay or something next to the fuse panel. Does anyone know what is going on?
The car does have an aftermarket alarm with the remote locks, could the alarm be causing this?
Thanks, Matt
Old Jul 29, 2002 | 12:09 AM
2vmodular's Avatar
inspect the 35amp circuit breaker in the fuse panel closely. if the circuit breaker has worked itself loose from the socket or otherwise failed, it will cause symptoms like you describe.
wiring diagrams for the power door lock circuit and pictures of the parts are avaliable at:
http://www.geocities.com/modularmoto...gen/powerlocks
Old Aug 16, 2002 | 01:17 AM
CrazyHawaiian's Avatar
Car: too many ...
Same thing happened to me this morning! I got in and none of the power door lock buttons on either door work anymore. The power window switches dont work either. I dont hear any clicking noises.
The windows (switches in center console) do work tho .... thinking its a fuse somewhere that only controls the stuff in the doors.
I'll need to take a look at it when I get home from work 2nite. If I cant find a fuse burnt out, does anyone have a chiltons or an owners manual that can tell me what fuse controls the stuff in the doors?
Thanks!!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
