Air/Fuel Ratio guage, which to buy??
Guest
Posts: n/a
My car is an 86 305, NON-COMPUTER carbed, 5 speed. see sig for mods.
so i want to get an A/F guage, but i dont know which i need or which to buy. i see in summit that auto-meter makes 2 1/16 electric one for about 50$
then i see one in the carb's section made by Edelbrock that looks like a square box with green, yellow, and red lights, for 124$, both are different.
i just want to know which is better for my set up. I currently have the 02 sensor plugged into my headers, but i doubt its doing anyting considering im not using a computer. So whch one should i use?
Car: 89 Camaro RS
Engine: 305 TBI
Well, I use the Autometer one.. and I'm pretty happy with it.. I like the Autometer one because it has more LEDS so it looks to be more accurate.
Car: 89 Camaro RS
Engine: 305 TBI
either one.. all they use is the reading from the o2 sensor.. the ecm has nothing to do with a A/F guage. So just install a o2 sensor.. and hook it up to the A/F guage.
I put the Edelbrock one in my 69 Chevelle but I "customized" it. I took the board out of that little black box and mounted it with the LED's sticking through the dash where the P RND21 would have been in a column shift car. There's lots of possibilities with the thirdgen for this kinda thing.
The one gage I think is mandatory is a vacuum gage. You can't make it out too good, but that's what replaced the clock right above my AFR meter. Simple hookup too
It's a great tool to diagnose problems right away, and can even help with the gas mileage if you keep it from bottoming out
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
