CAR WONT START
Old Apr 30, 2001 | 01:32 PM
BLACKACID's Avatar
CAR WONT START
I think it is the MAF. Is there any way to test or bypass the MAF to check if that is my problem???
Please help ASAP
87 2.8L
Stock...for now
Old Apr 30, 2001 | 05:41 PM
camaro 22's Avatar
does it crank at all, or do anything? i know for awhile there, my car wouldn't start, it wound't do anything. turned out to be the neuteral safty switch went back or needed re-adjusted
Old Apr 30, 2001 | 10:16 PM
BLACKACID's Avatar
Happened to me about 3 weeks ago. This time it cranks but wont start. Now I think it is the fuel pump Where is it??
Old May 2, 2001 | 09:44 AM
89RustangRemover's Avatar
fuel pump is located inside the fuel tank. it's a pain in the u know what to change it. but before u go through the trouble of changing it, try this. sit in your car half way. turn the key to the "ON" position. don't crank the engine. or u can have someone turn the key while u listen to it at the back. if the pump is good u should here it making a "whirring" sound. if it's quiet, then u'll need to change it. u can also disconnect the fuel lines from the throttle body and see if it's pumping gas. but i prefer the listening method. hope this helps ya out!
"WARNING: Objects in mirror are about to disappear VERY quickly!"
Old May 2, 2001 | 06:36 PM
86TransAmTPI's Avatar
It could be your ignition module.My old Trans Am wouldnt start and i tried everything,i heard my fuel pump on and all my fuses were fine,then my dad said change the ignition module,as soon as i did,it started right up.
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
Old May 2, 2001 | 08:47 PM
BLACKACID's Avatar
Ok. I turned the key to the On position...nothing. I connected power to G on the computer thing, pump turned on! I tried changing the fuel pump relay with no results. what else to try??
87 2.8L
Stock...for now
Old May 2, 2001 | 09:51 PM
BLACKACID's Avatar
What and where is the ignition module??
Old May 2, 2001 | 11:11 PM
BLACKACID's Avatar
Ok I found the problem
Its an in-line fuse near the battery, whenever I put in a new fuse it immediatly blows!! Where should i look for the short??
87 2.8L
Stock...for now
Old May 4, 2001 | 01:21 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The fuse by the battery is for the fuel pump. check the FP wiring from end to end, you will prolly find a short somewhere.
Old May 7, 2001 | 02:30 PM
MAXGTA2002's Avatar
Or you can check the relay where the wires come out they are usually already bare and twisted, could be grounding out, which will blow a fuse been there done that, hope this will help!
[This message has been edited by MAXGTA2002 (edited May 07, 2001).]
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
