89 bird, unhooked V6 computer, will gaurges work?
Old May 8, 2001 | 05:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i have heard yes, i have heard no, i am swapping a carbed V8 into the car, and can i hook the wires back up to the appropriate sending units and will it work? tach, oil, temp, volt? thanks
Wide Open Till You See God...Then Brake
Old May 10, 2001 | 03:47 PM
cfabe's Avatar
First off, the tach will not work. You need a tach from a v8 car. Best bet is to get a new gauge pod that has lights or gauges depending on what you have on the engine. If you are careful you won't have to re-pin the pod connectors (Get one from the same year). When i swapped gauges I had to reverse engineer the wiring by tracing the circuits on the back of both of the clusters.
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Glowsock
Sep 6, 2015 06:40 AM
1989formula5.7l
Aug 15, 2015 11:35 AM
stalkier
Aug 13, 2015 12:59 PM
dhonda200
Aug 11, 2015 11:50 PM
