Cooling fan still don't work after changing the relay, i think???
Old May 9, 2001 | 02:09 PM
camaro 22's Avatar
my cooling fan on my 91rs 305 tbi still don't work on it's own. i bought a new relay and i think i plugged it into the right one being there are two that are identical on the fire wall. can someone give me the color of the wires that go to the cooling fan relay for my car? also, if that isn't the problem, what else could it be? the guy i got the car off of has a wire tapped into somewhere so that i have to connect it to the battery everytime i drive in order for the fan to come on. do any of you suggest to use a manual switch in the car? and if so, can i just use that wire he already has somehow? i hope you can help. i don't know what else to do. thank you.
Old May 10, 2001 | 07:43 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Well it's hard to say what the previous owner did to the wiring, but I'd get in there and trace it all down. I've never heard of having to connect a wire to the battery every time just to get it to work. You say you have to do this, so you do know for sure that the fan actually works? The only other thing I know of in that system is the fan switch itself, located on the pass. side head, between #6 and #8 plugs. They go bad alot, plus they are designed to kick the fan on at about 238*. Most of the people you'll talk to on this board have probably changed their's to another type so that it comes on much sooner. Anyways, trace down your wiring - get someone to help you if you're not too sure about it, and then check your relay itself and/or the fan switch...
KAM
Old May 10, 2001 | 09:25 AM
89RustangRemover's Avatar
camaro 22
i have a '92 and experienced the same problem. the cooling fan relay is the one closest to the driver side fender(on the outside). now, i had the same problem, but the relay on mine was still good because the fan would come on with the A/C. but not by itself. the CTS (coolant temperature sensor right next to the thermostat housing.) had gone south. after changing that, it came on by itself! yippeee!!! ahem...sorry, got a little carried away... neway, try that assuming that the fan motor itself is still good. check the fan switch as suggested and remember that the fan isn't supposed to come on till about 238*-240* (sucks) as thunderstick said.
"WARNING: Objects in mirror are about to disappear VERY quickly!"
Old May 10, 2001 | 10:24 PM
Rallyssport's Avatar
I will agree with them 2. I also have a 92 camaro and the fan switch went out on me. So most likely it is that. I went through everything u did with the relays..it really sucked. hope ya get it workin.
Old Jan 24, 2002 | 10:52 AM
robert C's Avatar
i beleave { could be wrong } but i think the fan switch is on the passenger side on heads under exhaust manifold my 88 &90
is there but little advice do what i did after u fix it get a derale
adj. one so u can turn the fans on early like 195 instead of 230
fix the old one. if the derale dont come on 4 some reason the factory one will its only $40 bucks from jegs pt#025916759
u might find one local later
rob
Old Jan 24, 2002 | 10:59 AM
robert C's Avatar
i think the one on top is to the gauge just unplug it and start car
a code will come up then pull the code
Old Jan 25, 2002 | 04:44 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Had the same problem 2 months ago found out it was the relay after replacing the switch. If the fan doesn't come on with the A/C then it's the relay (Driver side closest one to fender), if it does then it could be the switch, either that or the motor in the fan is bad. To test the fan disconnect the harness and hot wire it to the battery directly from the harness the fan blades will spin. When I did it I found it alot easier to perform the test with the fan out of the car.
RazorN8
Jan 7, 2022 11:44 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
