Firewall holes
Old May 15, 2001 | 03:20 PM
JoeIROC's Avatar
Firewall holes
The only hole in the firewall that i've been able to use for wiring has been the hole just over the brake pedal.
However, I would like to wire an amp to my stereo, and i need to run a 10 gauge wire to the trunk. Where can the wire be routed? I am not sure of where holes in the firewall can be drilled either.
I basically would like to know if anyone has used any other holes in the firewall, because frankly, i'm stumped.
Joe
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Old May 15, 2001 | 06:34 PM
AmorgetRS's Avatar
I drilled a new hole in mine for my stereo wire. I drilled it just under the edge of the carpet toward the middle, which puts it out below the gauge stuff on the drivers side.
Hope this helps..
Douglas
Old May 15, 2001 | 09:30 PM
JoeIROC's Avatar
What was on the engine side of the hole?
86 IROC TPI 305
K&N Air filters
Dyno-Max cat-back
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
