Banging my fog lights
Old May 16, 2001 | 01:56 AM
robbob's Avatar
I think that I have a ground problem or other bad connection.
What happens is when I turn on my fog lights sometimes they will come on and other times not,or one will come on and the other doesn't.If I hit the lights with my fist they come on(most of the time).
Does anyone know where the connections are ground etc and how to get at them.(85 Trans Am).
Old May 16, 2001 | 09:51 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If they work when you hit them, there may be a short in the bulb or the filament may be broken and making contact whem you smack it. I'd change your bulbs and then trace the wires with a volt meter and check for faulty wiring. I assume you have 2 wires coming out of each light, one green (??) and one black. The black wire will ground the light in the chassis harness somewhere besides the light housing. I'd check the plugs for corrosion and then for cracks in the wiring.
Old May 17, 2001 | 09:40 AM
prepz28's Avatar
it's possible you may just need new bulbs. when my bulbs were dying sometimes they'd come on and sometimes they didnt. just a suggestion...
Old May 17, 2001 | 02:39 PM
robbob's Avatar
Thanks,I'll try replacing the bulbs and see if that helps.
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
