Help!!!Code 33 and 36!!!
Old May 21, 2001 | 05:05 AM
IROC KID's Avatar
I just did my trans swap and the check engine light was on,i hooked up the code scanner and got 33 and 36,any help or suggestions?
Old May 21, 2001 | 06:11 PM
Xenodrgn's Avatar
33: MAF (gm/sec HI)
36: MAF burn off
Good luck. I have no clue why it could be reading like that. I'll let one of the pro's tackle that one.
[EDIT]: The guys in Tech/General might be able to help you better... They see this alot. Also might wanna search that forum for stuff about this.
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles, mandrel bent cat-back pipes (but stock replacment muffler, Dynomax Turbo is on the way)
Maintenance since I bought it:
Bosch Platinum Plugs, wires, cap + rotor, Radiator, Water Pump, PCV, fluids and filters
[This message has been edited by Xenodrgn (edited May 21, 2001).]
Old May 21, 2001 | 06:17 PM
IROC KID's Avatar
Thanks,i just fixed the problem,it was a real stupid one too,the wire that connects under the MAF was disconnected.
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
